TRANS AM RACING
Re: TRANS AM RACING
« Reply #96 on: September 25, 2016, 02:57:15 PM »
Trans -Am
Re: TRANS AM RACING
« Reply #97 on: September 25, 2016, 02:58:15 PM »
Trans -Am
Re: TRANS AM RACING
« Reply #98 on: September 25, 2016, 02:59:28 PM »
Trans -Am
Re: TRANS AM RACING
« Reply #99 on: February 13, 2017, 03:08:49 PM »
Trans -Am
Re: TRANS AM RACING
« Reply #100 on: March 12, 2017, 09:14:00 PM »
A few more.
Fordors
Re: TRANS AM RACING
« Reply #101 on: March 12, 2017, 10:17:11 PM »
A few more.
Beppie, that Shelby KR500 pace car is rare, it is painted a special order color, Corporate Yellow. I'm not positive but that might have been the same yellow used on Yellow Cabs.
I know the basement floor is down there because it's holding everything up. I just can't see it anymore.
Re: TRANS AM RACING
« Reply #102 on: March 29, 2017, 08:48:40 PM »
A few more.
Paint code for that yellow is WT6066.
29bowtie
Re: TRANS AM RACING
« Reply #103 on: April 03, 2017, 03:30:14 PM »
Jim Hall Chaparral Camaro
Professionals built the Titanic, An Amateur built the Ark
29bowtie
Re: TRANS AM RACING
« Reply #104 on: April 03, 2017, 03:31:56 PM »
continued.
Re: TRANS AM RACING
« Reply #105 on: April 03, 2017, 04:07:25 PM »
Chaparral in Camaro's Clothing
September, 2004,By George Mattar
Many will readily tell you that, to them, 1970 was the pinnacle of muscle car design and performance. Horsepower reached Everest altitude, and to keep aesthetics astride of earthiness, General Motors debuted a new-generation Chevrolet Camaro, arguably one of GM's most beautiful cars ever. That it would race was a given.
   In late 1970, SCCA Trans-Am racing was being contested in full fury by all of the U.S. manufacturers. The new 1970 1/2 Camaro competed against Ford, AMC, Dodge and Plymouth. The drivers were as iconic as the pony cars themselves: Donohue, Gurney, Jones and Follmer. The manufacturers, always looking to capitalize, offered limited numbers of production cars resembling the racers. Most memorable are the AAR 'Cuda, Challenger T/A and, of course, the Pontiac Trans Am Firebird, which finally had its wings clipped in 2002, when GM killed the car, along with the Camaro.
Though it never reached lexicon status like its Pontiac cousin, the Camaro has a lofty place in Trans-Am racing history. In 1970, Jim Hall, Vic Elford, Ed Leslie and Joe Leonard drove refrigerator-white Chaparral Camaros, their roundels set into huge bowties on their sides, built in Hall's famed Midland, Texas, shop, which had already spawned his Chevy-powered Can-Am and international sports cars.
Just three Chaparral Camaros were built. The sole remaining example is owned by Mark, Linda and Mariah Mountanos of Ukiah, California. Mark said his documentation dates back to Hall's own construction of the race car. Physical tell-tales from Chaparral also backed up the paper trail.
"The fender flares were all wrong, so we had to cut them off and put on new ones made from the original molds," he said. "The car needed a lot of work, but there was no rust. The single biggest item that proved this car was real, other than all the documentation I have, is the dash, molded from fiberglass by Hall. It is the prettiest dash ever built for a race car."
Elford, the great rally and European endurance driver, drove the car now owned by Mark to victory at Watkins Glen in August 1970, with Hall as his co-driver. Despite winning earlier Trans-Am titles in the hands of Donohue and his patron, Roger Penske, Camaros were not nearly as successful in 1970 as the Javelins and Mustangs. Hall said that was because of that dreaded word in racing-weight. Mountanos believes Hall, an engineering and aerodynamics freethinker, simply wasn't used to a comparatively crude racer like a Camaro and lacked the time to properly develop it.
"He Hall was more used to driving Indy cars, and others that were much more aerodynamic than any production car," Mountanos said.
Mountanos bought the Chaparral Camaro, in dire need of a total restoration, from an Arizona collector about six years ago. After spending about $100,000, it is now restored "just the way" Hall built it in 1970. Mountanos and his wife are part of a California-based group of about 60 enthusiasts of the series who call themselves Historic Trans Am (www.HistoricTransAm.com). Included in the car's documentation are Hall's original chassis blueprints.
"We run together as a group at vintage races. We are very strict in what we do. To be in the group, the car must be raced as it was built. No replicas are allowed. We have to stick with these cars the way they were," said Mountanos, 47.
The car has a period-correct, 302-cu.in. small-block V-8, punched out to about 304 cubic inches, a smidgen shy of the maximum of 305 permitted in 1970. The fuel system's heart is a 750-cfm Holley double-pumper atop a GM dual-plane aluminum intake. The heads are ported, polished and fitted with Manley valves and guides.
Mountanos's personal mechanic, Jim Koehler, who restored the car along with body and paint specialist Ron Duwe, estimates 475hp. The car runs the quarter in 10.70 and, depending on gearing-4.11 or 4.56 with a cooler-can hit 200 mph. He figures 0-60 times are in the high 4s.
The small-block has 12.0:1 compression, a solid-lifter Crane cam with .650 lift and 260 degrees duration, and four-bolt mains to withstand the 7,200-rpm shifts Mountanos slams through the Borg Warner Super T-10. A stock 12-bolt Chevy rear spins 4:11 gears to the 15 x 8 Minilite wheels mounted with Goodyear Blue Streaks. The anchors are Hurst-Airheart ventilated 12-inch, four-piston discs with Performance Friction carbon-metallic pads.
High-speed stability is assured by double-adjustable Konis on all four corners. The rear suspension has parallel semi-elliptic leaf springs, a Panhard bar and 3/4-inch anti-roll bar. Up front are unequal-length upper and lower A-arms, coils and a python-thick 1 3/16th-inch anti-roll bar. Nylon bushings are used exclusively. The acid-dipping that teams were allowed in 1970 slimmed the Chaparral Camaro to about 3,375 pounds, as opposed to the stock 3,800.
Mountanos, his wife and daughter all enjoy racing. They also own the only two surviving Pontiac Trans Am racers, originally owned by Jerry Titus, who was killed in the third car in 1970 at Road America.
"My wife is a ski instructor, but she got into a car and she loved it," he explained. "She races, too. Our daughter has raced go-karts, and we keep it all in the family."
29bowtie
Re: TRANS AM RACING
« Reply #106 on: September 08, 2017, 06:38:51 PM »
George will probably remember this one, Michael Oleyar, from Freeland Pa. who used to come to Westwood every year and they would come to our high school as promo in exchange for the use of the automotive shop. Had a small crew, so a few of us and the teacher pitched in as crew.
29bowtie
Re: TRANS AM RACING
« Reply #107 on: October 23, 2017, 06:33:04 PM »
 8) ;) ;)
29bowtie
Re: TRANS AM RACING
« Reply #108 on: November 01, 2017, 01:40:24 PM »
29bowtie
Re: TRANS AM RACING
« Reply #109 on: December 04, 2017, 03:48:37 PM »
 8) 8)
29bowtie
Re: TRANS AM RACING
« Reply #110 on: December 18, 2017, 02:09:38 AM »
Mark Donahue on the pole for the 1969 SCCA Trans Am race at Kent Wa.(the road race grid has its start line at the 1/4 mile finish line) in his Roger Penske-owned, GM (backdoor) backed Camaro. Trans Am,
