Residual valve failure
pat
  • Jack off all trades,master of nun!
« on: April 27, 2013, 08:39:57 PM »
  What happens when a residual valve in a brakeline goes bad? Are the symtoms the same as a bad mastercylinder?   Thanks,Pat
langy
Re: Residual valve failure
« Reply #1 on: May 02, 2013, 01:03:06 PM »
No not the same, the system will stll work but you may see more pedal travel as the pistons will retract further than normal into the cylinder.
pat
« Reply #2 on: May 02, 2013, 01:28:32 PM »
OK,thanks.
