Tech - How about some pipes ? The exhaust thread
IBILTIT
Re: Tech - How about some pipes ? The exhaust thread
« Reply #48 on: August 20, 2016, 02:55:29 PM »
after a long absence due to the economy and family matters I finally got back on the "replica" Victoria. Since I haven't fired this engine in a year or so I figured I had better get the headers built so I can run it. I was going to have a local guy build them but he figured his work was gold so I'm doing myself. I've done exhaust work before but never a set of headers, the width of this 507" Cad makes production headers like Sandersons stick out too far necessitating no hood or a HUGE bulge in a nice Rootlieb hood. I think by careful design and measuring I can get away with a small one.
I'm building (trying is a better word) a set of 4 into 2, 1 7/8" 16 ga. mandrel bent mild steel headers that transistion into a 2"x 2.5" SS merge collector. Performance isn't really an issue here as this engine is basically a diesel, dyno'd 466 hp @ 5,000 rpm and 535 lbs. ft. torque @ 4300 rpm. This is with a pump gas friendly 8.7:1 compression, I could have really got some ponies if I built it to 10:1 but I just don't need it nor the problem of running high octane gas.
I'll start off with just the pics I have of how the headers are fab'd to clear the r&p steering shaft, as you can see, the 2 middle tubes drop down and curve toward the block then drop down again. Then they will transition into 2 seperate 2" 90 deg. bends stacked on top of each other to wards the merge collector which will sit as it shows for clearance purposes. The 2 outside tubes will transition into the center tubes and that will take some time measuring, grinding and fitting. I'm not sure just how I'm going to do that.....yet. The one pic shows the distance between the tube and the Flaming River shock absorber type coupler, there's about 1.5" of clearance, the headers will be ceramic coated so hopefully the heat won't be too big of a problem.
Of course when you're doing something for the first time you do make mistakes, I ruined a couple of mandrel bends and ran out of material so I just put in an order for 8 more bends and some 2.5" straight tubing for the exhaust system. I will get back on it when the big brown truck shows up. Anyway so far so good I hope, I really like fabbing parts so hopefully I will be happy with the outcome. Here's some pics so far and I will update as progress continues .......... Dave
IBILTIT
« Reply #49 on: August 20, 2016, 02:56:15 PM »
Don't pay any attention to the picture date, every pic I take has ther same date. I worked on the back cyl. tube tonight but screwed it up. Here's another picture.
Happydaze
« Reply #50 on: August 20, 2016, 02:57:00 PM »
Might be the camera angle but it looks to me as if you might be on course for an unmolested hood side, which is nice:)
Looking good and looking forward to further pics.
Chris
Merlin
  • Misfit Extraordinaire.
« Reply #51 on: August 20, 2016, 02:57:15 PM »
Looking good so far Dave.
I'm just your average misfit with enough knowledge to be dangerous.
IBILTIT
« Reply #52 on: August 20, 2016, 02:57:48 PM »
Thanks for the positive reply's ........... Happydaze you might be right but the front cyl. is going to be REALLY close. Here's another pic to show the clearance, hopefully my new bends come by Weds.
IBILTIT
« Reply #53 on: August 20, 2016, 02:58:19 PM »
Cut and fit ...... grind and fit ..... measure over and over, DAMN it!!!!! too much grinding, screwed that one up. Anywho, after a bunch of hours I finally got the drivers side pretty much squared away for now. They really don't look too bad, function is the main thing, I had to be careful fitting the tubes due to the heat issue on the column and specially careful to leave room to get the header bolts in and out. As I figured though, the front tube is almost touching the hoodline, these bends have a 3" radius but I found some with a 2.5" radius which would give me a little more room. Ordered 2 of them this morning and waiting on the other 90's to complete the transition to the 2 into 1 collector. The pass. side parts and exhaust tubing should be here in a couple of days ............ film at 11, Dave
« Reply #54 on: August 20, 2016, 02:58:27 PM »
Those'll look great once you get them sorted out
« Reply #55 on: August 20, 2016, 02:58:42 PM »
Clean and simple. Great fitting job, they should finish off nice!
« Reply #56 on: June 21, 2017, 10:01:40 PM »
Fenton's
« Reply #57 on: August 01, 2017, 09:08:52 PM »
Brizio's shop
« Reply #58 on: August 10, 2017, 04:00:56 PM »
Chick Koszis roadster
« Reply #59 on: August 10, 2017, 04:03:24 PM »
Nice flow to them.
« Reply #60 on: August 10, 2017, 04:05:54 PM »
Deuce
« Reply #61 on: August 10, 2017, 04:07:03 PM »
Roadster
