Style & Tech - Headlights & Headlight Mounts
3 deuces
Re: Headlights - Styles & Tech
« Reply #16 on: July 27, 2016, 09:23:22 AM »
The problem is the tags were also painted over.Maybe the only answer is to buy new tags,but would prefer to keep what i have.
« Reply #17 on: July 27, 2016, 09:24:11 AM »
If they used a cheap paint easyoff might work, or as Beppie said try some convetional paint stripper on a brush on the edge of a tag.
3 deuces
« Reply #18 on: July 27, 2016, 09:24:29 AM »
Thanks for the ideas.I will try the paint stripper first to see if i can save them .
193257
« Reply #19 on: July 27, 2016, 09:26:00 AM »
3 deuces,
I make reproduction tags.   Here's a pic on my tags.    Rick Bales
3 deuces
« Reply #20 on: July 27, 2016, 09:29:50 AM »
I will probably buy new tags as i have been unable to remove paint with out removing paint from tags also.Thanks for photo of repro tags.
hb32
Re: Headlights & Headlight Mounts- Styles & Tech
« Reply #21 on: July 27, 2016, 09:46:27 AM »
My original 682c`s not the new repo`s. Went thru at least 6 sets to get a nice pair. Markers are converted to signals and the original steel back lamps have been modified to use halogen bulbs.
" Life is too short to drive a boring vehicle "
ohio32
« Reply #22 on: July 27, 2016, 09:47:46 AM »
33 Commercial.  Commercials have painted buckets not stainless steel.
seadog
« Reply #23 on: July 27, 2016, 09:48:34 AM »
Question??  I have a set of 682c's that I want to use on my 5 window.  I've got them painted, wired up for turn signals on top...all ready to go, EXCEPT I can't find a source for the rubber gasket that goes between the turn signal bezel and the headlight bucket.  Can anyone on here point me to a source.  'Been thinking about seeing if I can make a pair out of an old inner tube, but would rather have something that's not makeshift.  Thanks.
hb32
« Reply #24 on: July 27, 2016, 09:48:57 AM »
Try this.
http://www.thehotrodcompany.com/shopnow/show_item.asp?product_id=OTBGKT%2D1
Pretty straight forward and easy to make.
seadog
« Reply #25 on: July 27, 2016, 09:49:11 AM »
Thanks...I have those, they go around the parking light bulb.  I'm looking for the rubber gasket that goes between the parking light bezel and the main headlight bucket.
hb32
« Reply #26 on: July 27, 2016, 09:49:32 AM »
I don`t recall seeing one on any of the lights I have/had.
flatheadv8s
« Reply #27 on: July 27, 2016, 09:53:15 AM »
Arrow Model 775-HP
Life is like a toilet roll. The closer you get to the end the faster it goes.
« Reply #28 on: July 27, 2016, 09:54:22 AM »
Who says size matters???  Went small on the Chemical City Coupe.  I have the headlights mounted on a quick-disconnect headlight bar and usually run the car without headlights for more of a competition look.  I can have them out of the trunk and installed in about 3 minutes.
Here's pics with and without the lights:
« Reply #29 on: July 27, 2016, 10:03:34 AM »
My restored BLC lights.
My names John,I have always liked hotrods,and mainly 32 fords,thanks to my dad.
« Reply #30 on: July 27, 2016, 10:06:48 AM »
KINGBEE'S
« Reply #31 on: July 27, 2016, 10:16:38 AM »
ARROWS
