Deuce Pickups
HOTRODPRIMER
Re: Deuce Pickups
« Reply #16 on: June 10, 2016, 08:09:51 AM »
Does the passenger car grille shell interchange with the truck shell? Or does it have to be modified?
The 32 pickup shell is a one piece,,meaning the insert is stamped into the shell when it was made,,,
However the passenger shell and insert can be used in place of the truck shell. HRP
Re: Deuce Pickups
« Reply #17 on: June 10, 2016, 08:12:13 AM »
In the rough!
Dave_Lantto
Re: Deuce Pickups
« Reply #18 on: June 10, 2016, 08:13:53 AM »
A shot of mine to freshen up the list. HRP's is definitely the top truck on this post.
Striper
    • Whetstone Pinstriping
Re: Deuce Pickups
« Reply #19 on: June 10, 2016, 08:14:11 AM »
What a cool look'n hotrod truck !
Anything worth doing is worth doing right . -- Frank Kurtis
M_S
Re: Deuce Pickups
« Reply #20 on: June 10, 2016, 08:14:41 AM »
I agree, couldn't pick a better color for it.
Dave_Lantto
Re: Deuce Pickups
« Reply #21 on: June 10, 2016, 08:15:01 AM »
Striper & M_S, thanks for the nice comments. Paint color is GM War Bonnet Yellow, from early 70s Corvettes.
Baron
Re: Deuce Pickups
« Reply #22 on: June 10, 2016, 08:15:39 AM »
Deuce Engineering ‚an almost finished project. Had it at my shop for the exhaust. Should be out this spring.
Re: Deuce Pickups
« Reply #23 on: June 10, 2016, 08:15:59 AM »
Yours is the perfect hiboy truck !  And I like the warbonnet yellow paint too.
Re: Deuce Pickups
« Reply #24 on: June 10, 2016, 08:16:26 AM »
Another beaut !  Keep 'em coming fellas !
HOTRODPRIMER
Re: Deuce Pickups
« Reply #25 on: June 10, 2016, 08:16:45 AM »
My thoughts exactly!
Is it a 33 or 34 cab? HRP
Re: Deuce Pickups
« Reply #26 on: June 10, 2016, 08:17:18 AM »
Actually it's a late 32 cab with early doors (no reveal around the hinges). The 33/34 firewall that was adapted to it has had a 1 inch plus strip added to push it out from the cab more than it would be stock. The picture on the flatbed shows the hardly noticeable difference.
A 32 pickup has a cowl that is 4 inches shorter than all other body styles. All that 4 inches comes out of the leg room. What I did was put back as much of that leg room as I could. The 33/34 firewall gives about 1 1/2 inches more leg room than the 32 and the 1 inch plus added strip just about gets it all back.
Of course, with that firewall protruding way into the engine room, I had to lop off two cylinders from the 350 small block. But that's another story.....
Dave_Lantto
Re: Deuce Pickups
« Reply #27 on: June 10, 2016, 08:17:43 AM »
Great looking pickup! Sure wish I had the extra 4 inches of leg room!
JOEWEE
  • 32 ford rpu
    • Hubgarage
Re: Deuce Pickups
« Reply #28 on: June 10, 2016, 08:18:01 AM »
 :) awesome job! Looks great
Joey Realmuto
Grenada MS
32 Ford rpu
Re: Deuce Pickups
« Reply #29 on: June 10, 2016, 08:18:40 AM »
More pickups for inspiration !  I just located a nice '32 pickup grille, now all I need is the rest !  A couple of hiboys for y'all
Re: Deuce Pickups
« Reply #30 on: June 10, 2016, 08:19:15 AM »
Ed Cousin's famous truck.
Baron
Re: Deuce Pickups
« Reply #31 on: June 10, 2016, 08:19:57 AM »
I put this little Deuce Pick together about 25 years ago(see post 11). Sold it to Deuce Engineering about 1/2 way through the build. Found this picture recently on the internet. Still looks good today.
