32 Frame Construction
gbfab
« on: April 01, 2016, 07:26:04 PM »
Boxing plates cut out and tacked in place ready to weld
gbfab
Re: 32 Frame Construction
« Reply #1 on: April 01, 2016, 07:27:39 PM »
Cross members in and ready to weld
« Reply #2 on: October 28, 2016, 12:59:20 AM »
Any up dates ?
gbfab
« Reply #3 on: October 28, 2016, 02:46:02 PM »
Booster, master cyl. trans cooler, and 4 bar mts added.
gbfab
« Reply #4 on: October 28, 2016, 02:47:20 PM »
Raised rear X-member and bobbed frame ends finished.
gbfab
« Reply #5 on: October 28, 2016, 02:48:29 PM »
Frt. X-member with shock mts. and Cross steer done.
gbfab
« Reply #6 on: October 28, 2016, 02:50:45 PM »
Body fit to frame ready to start the inner steel structure. Also fitting inner and outer door and truck skins.
gbfab
« Reply #7 on: October 28, 2016, 02:52:31 PM »
Front fire wall loop about ready to weld up and fit.  All inner structure is 1x1x.095 wall tube.
gbfab
« Reply #8 on: October 28, 2016, 02:53:40 PM »
Door hinges done with more inner supports.
gbfab
« Reply #9 on: October 28, 2016, 02:56:05 PM »
I made door hinges from 1/4" cold rolled with 1/4 cold rolled back plates
gbfab
« Reply #10 on: October 28, 2016, 03:01:02 PM »
Steel reinforcement is bonded and flush riveted to inner skins before the outer skins are fit and bonded.
gbfab
« Reply #11 on: October 28, 2016, 03:02:01 PM »
Inner door skin from the inside
gbfab
« Reply #12 on: October 28, 2016, 03:03:17 PM »
Rear structure is also .095 wall tube set back 4 inches for more seat clearance.
gbfab
« Reply #13 on: October 28, 2016, 03:04:57 PM »
I cut the trunk floor out and will raise it 2 1/2 inches for more clearance.
gbfab
« Reply #14 on: October 28, 2016, 03:06:50 PM »
Inner skin for the trunk is also stiffened with 3/4 steel.  Hinge plates are welded to the tubes also.
gbfab
« Reply #15 on: October 28, 2016, 03:10:39 PM »
6 inch roll pan from Ravon ready to be glassed on from the inside.  Best fitting one I've found.  Very little trimming.  Others I've had to narrow or widen by up to one inch.
